Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Compaq 515 Wireless Card Replacement
Qué necesitas
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    Pregunta a FixBot
  2. HP Compaq 515 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
    Pregunta a FixBot
  3. HP Compaq 515 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    Pregunta a FixBot
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
    Pregunta a FixBot
  5. HP Compaq 515 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
    Pregunta a FixBot
  6. HP Compaq 515 Wireless Card Replacement: paso 6, imagen 1 de 2 HP Compaq 515 Wireless Card Replacement: paso 6, imagen 2 de 2
    • Slide the wireless card backing towards you to remove it from the laptop.
    Pregunta a FixBot
  7. HP Compaq 515 Wireless Card Replacement: paso 7, imagen 1 de 1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
    Pregunta a FixBot
  8. HP Compaq 515 Wireless Card Replacement: paso 8, imagen 1 de 1
    • Remove the two .4 cm screws with a PH00 bit.
    Pregunta a FixBot
Conclusión
Aleks B
Miembro Desde 03/19/18
337 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 57
Todo El Tiempo: 495
