Saltar al contenido principal
HP Compaq 515 Keyboard Replacement
Qué necesitas
  1. HP Compaq 515 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Turn the laptop over, the screws for the keyboard are in the middle and left of the device
  2. HP Compaq 515 Keyboard Replacement: paso 2, imagen 1 de 1
    • Unscrew the two 0.725 cm Screws with a PH1 screwdriver bit
    • Make sure to put the screws in a safe place so you don't lose them
  3. HP Compaq 515 Keyboard Replacement: paso 3, imagen 1 de 1
    • Flip the laptop over and open the screen
  4. HP Compaq 515 Keyboard Replacement: paso 4, imagen 1 de 2 HP Compaq 515 Keyboard Replacement: paso 4, imagen 2 de 2
    • Gently use a plastic spudger to remove the plastic holder at the top of the keyboard
  5. HP Compaq 515 Keyboard Replacement: paso 5, imagen 1 de 1
    • Gently use a plastic spudger to remove the keyboard from its holders
    • Be careful as there is a wire connecting the keyboard to the laptop
  6. HP Compaq 515 Keyboard Replacement: paso 6, imagen 1 de 1
    • Carefully unclip and remove the large black wire that is connecting the keyboard to the laptop
Conclusión
Kirsten Harnden
Miembro Desde 03/13/18
259 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 354
