Saltar al contenido principal
HP Compaq 515 Hard Drive Replacement
Qué necesitas
  1. HP Compaq 515 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
  2. HP Compaq 515 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
  3. HP Compaq 515 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
Conclusión
Aleks B
Miembro Desde 03/19/18
337 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 335
