Saltar al contenido principal
HP Compaq 2510p RAM Replacement
Qué necesitas
  1. HP Compaq 2510p RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: paso 2, imagen 1 de 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: paso 3, imagen 1 de 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: paso 4, imagen 1 de 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: paso 5, imagen 1 de 1
    • Remove the old RAM by lifting it upwards, then pulling.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 767
