Saltar al contenido principal
HP Compaq 2510p Power/audio bar Replacement
Qué necesitas
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: paso 1, imagen 1 de 1
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: paso 2, imagen 1 de 1
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: paso 3, imagen 1 de 1
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: paso 4, imagen 1 de 1
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: paso 5, imagen 1 de 1
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: paso 6, imagen 1 de 2 HP Compaq 2510p Power/audio bar Replacement: paso 6, imagen 2 de 2
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: paso 7, imagen 1 de 1
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: paso 8, imagen 1 de 2 HP Compaq 2510p Power/audio bar Replacement: paso 8, imagen 2 de 2
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: paso 9, imagen 1 de 1
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: paso 10, imagen 1 de 1
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
Conclusión
Una persona más ha completado esta guía.
Derek Kohansky
Miembro Desde 10/26/16
297 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 393
