Saltar al contenido principal
HP Compaq 2510p Bluetooth Adapter Replacement
Qué necesitas
  1. HP Compaq 2510p Bluetooth Adapter Replacement, Bluetooth Adapter: paso 1, imagen 1 de 1
    • Place the laptop upside down, with the battery facing away from you. Towards the bottom-middle of the laptop, you should see a small panel with a Bluetooth symbol.
  2. HP Compaq 2510p Bluetooth Adapter Replacement: paso 2, imagen 1 de 1
    • There is 1 screw on the panel you located in step one. Use your Philips head screwdriver to remove the single screw.
  3. HP Compaq 2510p Bluetooth Adapter Replacement: paso 3, imagen 1 de 1
    • Remove the Bluetooth panel by pulling it with your finger.
    • Pull gently as there is a wire connecting the laptop and the adapter.
  4. HP Compaq 2510p Bluetooth Adapter Replacement: paso 4, imagen 1 de 1
    • Pull the adapter to the left exposing its underside. Locate and remove its only screw using your Phillip's head screwdriver.
  5. HP Compaq 2510p Bluetooth Adapter Replacement: paso 5, imagen 1 de 1
    • Separate the Bluetooth adapter by pulling it from its casing.
  6. HP Compaq 2510p Bluetooth Adapter Replacement: paso 6, imagen 1 de 1
    • Remove the adapter by pulling on the base of the connecting wires and the adapter, in opposite directions.
    • Use moderate force.
Conclusión
3 personas más completaron esta guía.
Derek Kohansky
Miembro Desde 10/26/16
297 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 414
