Saltar al contenido principal
HP Color LaserJet Pro MFP M277dw toner cartridges Replacement
Qué necesitas
  1. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: paso 1, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, your printer: paso 1, imagen 2 de 2
    • find the two notches on the side that allow you to easily open the front panel.
  2. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: paso 2, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, Open the Front Panel: paso 2, imagen 2 de 2
    • Don't pull too hard as you might break your printer.
    • Pull both notches
  3. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: paso 3, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement, pull out the tray that contains the toner cartridges: paso 3, imagen 2 de 2
    • pull on the BLUE handle.
  4. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 4, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 4, imagen 2 de 2
    • take out your printer cartridges one-by-one.
    • dispose properly!
  5. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 5, imagen 1 de 1
    • beware that there are little markings in each slot that says the color DO NOT MIX THESE UP
    • do not mix the cartridges up
    • do not touch the blue/green roller on the bottom of your new cartridges.
  6. HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 6, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 6, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw toner cartridges Replacement: paso 6, imagen 3 de 3
    • put them back in the printer
    • look at the pictures for more info
    • push the tray back and close the front panel
Conclusión
To reassemble your device, follow these instructions in reverse order. or look at the pictures on step 6.
2 personas más completaron esta guía.
Seizure Salad
Miembro Desde 01/12/18
2,479 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,516 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 16
Ultimos 30 días: 71
Todo El Tiempo: 2,981
