Saltar al contenido principal
HP Color LaserJet Pro MFP M277dw Power Module Replacement
Qué necesitas
  1. HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: paso 1, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: paso 1, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement, Power Module: paso 1, imagen 3 de 3
    • Open and lower the back panel by pulling it down.
    • Remove one Phillips #2 10 mm screw.
  2. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 2, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 2, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to remove the right side panel of the printer.
    • Flipping the printer on its side, with the right side facing up, will make it easier to remove.
  3. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 3, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 3, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 3, imagen 3 de 3
    • Remove two Phillips #2 12mm screws.
    • Remove four different pin connectors that attach to the power module located at the bottom.
    • Removing the white connector is made easier with assistance of a spudger/flat tip that loosens the clamp.
  4. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 4, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 4, imagen 2 de 2
    • Remove two Phillips #2 10mm from the left (front) and right (back) side that attach the power module to the printer.
  5. HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 5, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 5, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Module  Replacement: paso 5, imagen 3 de 3
    • Slowly lift the power module from the printer using both hands.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S4-G2, White Fall 2018 Miembro de Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
3 Miembros
10 Guías creadas
2 comentarios
Hello, wäre can i buy the power supply? Thank you
Jakob Hetzendorfer - Contestar
Thanks a lot - also works for model M281fdw
patrik maurer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 81
Todo El Tiempo: 4,409
