Saltar al contenido principal
HP Color LaserJet Pro MFP M277dw Power Button Replacement
Qué necesitas
  1. HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: paso 1, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: paso 1, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement, Power Button: paso 1, imagen 3 de 3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove right side panel by prying it off.
    • Flipping the printer onto its side makes it easier to remove the side panel.
  2. HP Color LaserJet Pro MFP M277dw Power Button Replacement: paso 2, imagen 1 de 2 HP Color LaserJet Pro MFP M277dw Power Button Replacement: paso 2, imagen 2 de 2
    • Lower the front panel by pulling it down from the upright position.
    • The button cover should come off with the panel, if it does not be sure to remove it.
  3. HP Color LaserJet Pro MFP M277dw Power Button Replacement: paso 3, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: paso 3, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Power Button Replacement: paso 3, imagen 3 de 3
    • Remove two Phillips #2 8mm screws.
    • Unplug the wire connecting the power button to the circuit board by gently pulling them apart.
Conclusión
2 personas más completaron esta guía.
Christopher Fahey
Miembro Desde 10/08/18
774 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G2, White Fall 2018 Miembro de Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
3 Miembros
10 Guías creadas
2 comentarios
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
Ajay Kumar Singh - Contestar
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
Sheila Shook - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 2,705
