Introducción
This is a replacement guide for the power button on the HP Color LaserJet Pro MFP M277dw. You will need plastic opening tools as well as a Phillips #2 screwdriver.
Qué necesitas
Lower the back panel by pulling it down.
Remove one Phillips #2 10mm screw.
Use the plastic opening tool to remove right side panel by prying it off.
2 personas más completaron esta guía.
2 comentarios
How to make the catridge tray out ? As one side(left) of the tray is not coming out.
I am not sure if it’s the power button or power module. How do I determine that? Where do I get the parts?
