Saltar al contenido principal
HP Color LaserJet Pro MFP M277dw Display Replacement
Qué necesitas
  1. HP Color LaserJet Pro MFP M277dw Display Replacement, Display: paso 1, imagen 1 de 1
    • Lift up the top of the printer by pulling up on it.
  2. HP Color LaserJet Pro MFP M277dw Display Replacement: paso 2, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Display Replacement: paso 2, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Display Replacement: paso 2, imagen 3 de 3
    • Remove one Phillips #2 15mm screw.
    • Use the plastic opening tool to remove the top of the display component.
    • The cable connecting the display to the motherboard should be visible.
  3. HP Color LaserJet Pro MFP M277dw Display Replacement: paso 3, imagen 1 de 3 HP Color LaserJet Pro MFP M277dw Display Replacement: paso 3, imagen 2 de 3 HP Color LaserJet Pro MFP M277dw Display Replacement: paso 3, imagen 3 de 3
    • Lower the back panel by pulling it down.
    • Remove one Phillips #2 10mm screw.
    • Use the plastic opening tool to remove the left side panel.
    • Flipping the printer onto its side makes it easier to remove the panel and access the motherboard.
  4. HP Color LaserJet Pro MFP M277dw Display Replacement: paso 4, imagen 1 de 1
    • Unplug the display from pink cable from the circuit board.
    • Connecting a new display will require you to feed the cable through the printer.
Conclusión
5 personas más completaron esta guía.
Christopher Fahey
Miembro Desde 10/08/18
774 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G2, White Fall 2018 Miembro de Cal Poly, Team S4-G2, White Fall 2018
CPSU-WHITE-F18S4G2
3 Miembros
10 Guías creadas
8 comentarios
where do you get a new screen
Seizure Salad - Contestar
Would like to know too where to get a new screen
Bernd Kohnen - Contestar
“Connecting a new display will require you to feed the cable through the printer”
Well, it’s actually not too complicated, you don’t need to take any additional parts to do it. Just take out the display (also need to unscrew two black screws inside, first and then grounding cable) and pull the cable out (do it a bit harder as it’s tight), and then when you change the display, feed the cable through by using different path.
In terms of finding the display, it’s not easy, as hp doesn’t sell it. You are may be lucky to find it on eBay…
az2181 - Contestar
looked on ebay could not find maybe you have another place
mariamaxwell88 - Contestar
where we can get the new display could you advise.
Mahmoud Mizo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 110
Todo El Tiempo: 9,758
