Introducción
If the System Board of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the hard drive. For this guide, you will need the Phillips #1 screwdriver .
Qué necesitas
Position the device upside-down on a flat, level surface with the USB ports facing you.
Remove the four Phillips M2.5×4.0 screws by using the Phillips #1 Screwdriver, that secure the system board to the computer.
Casi Terminas!
Conclusión
