Introducción
If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
Qué necesitas
Position the device upside-down on a flat, level surface with the USB ports facing you.
Una persona más ha completado esta guía.
