Introducción
In this guide, we will be showing you how to remove the keyboard from your HP Chromebook CB2L.
  1. Flip the Chromebook over so the blue panels are showing.
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. Remove six 4.77mm screws using the Phillips #1 screwdriver.
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
    • Remove the speakers and battery.
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
Conclusión
Nathan Petrie
Miembro Desde 31/10/18
277 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G4, Harley Fall 2018 Miembro de IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
3 Miembros
2 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 29
Todo El Tiempo: 46
