Saltar al contenido principal
HP Chromebook 14-x015wm Battery Replacement
Qué necesitas
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Chromebook 14-x015wm Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: paso 2, imagen 1 de 1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: paso 3, imagen 1 de 2 HP Chromebook 14-x015wm Battery Replacement: paso 3, imagen 2 de 2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,388
