Saltar al contenido principal
HP Chromebook 14-x013dx Screen Replacement
Qué necesitas
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: paso 1, imagen 1 de 3 HP Chromebook 14-x013dx Screen Replacement, Screen: paso 1, imagen 2 de 3 HP Chromebook 14-x013dx Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: paso 2, imagen 1 de 2 HP Chromebook 14-x013dx Screen Replacement: paso 2, imagen 2 de 2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: paso 3, imagen 1 de 2 HP Chromebook 14-x013dx Screen Replacement: paso 3, imagen 2 de 2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: paso 4, imagen 1 de 1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: paso 5, imagen 1 de 2 HP Chromebook 14-x013dx Screen Replacement: paso 5, imagen 2 de 2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: paso 6, imagen 1 de 3 HP Chromebook 14-x013dx Screen Replacement: paso 6, imagen 2 de 3 HP Chromebook 14-x013dx Screen Replacement: paso 6, imagen 3 de 3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
Conclusión
3 personas más completaron esta guía.
NHerbert
Miembro Desde 09/28/17
602 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G6, Nance Fall 2017 Miembro de USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,829
