Saltar al contenido principal
HP Chromebook 14-x013dx Keyboard/Touchpad Replacement
Qué necesitas
  1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: paso 1, imagen 1 de 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: paso 1, imagen 2 de 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 2, imagen 1 de 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 3, imagen 1 de 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 3, imagen 2 de 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 4, imagen 1 de 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 4, imagen 2 de 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 5, imagen 1 de 3 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 5, imagen 2 de 3 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: paso 5, imagen 3 de 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
Conclusión
4 personas más completaron esta guía.
NHerbert
Miembro Desde 09/28/17
602 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G6, Nance Fall 2017 Miembro de USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,294
