Saltar al contenido principal
HP Chromebook 14-x010wm Touchpad Replacement
Qué necesitas
  1. HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: paso 1, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: paso 1, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement, Touchpad: paso 1, imagen 3 de 3
    • Before starting the fix, make sure the computer is turned off, the power is disconnected, and all external devices are disconnected as well.
    • Close the laptop lid.
    • Turn the laptop upside-down.
  2. HP Chromebook 14-x010wm Touchpad Replacement: paso 2, imagen 1 de 2 HP Chromebook 14-x010wm Touchpad Replacement: paso 2, imagen 2 de 2
    • Remove the two larger rubber screw covers.
    • Remove the two smaller rubber screw covers.
    • Remove the middle rubber screw cover.
  3. HP Chromebook 14-x010wm Touchpad Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the thirteen 5.7 mm screws located on the back of the device as shown.
  4. HP Chromebook 14-x010wm Touchpad Replacement: paso 4, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 4, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 4, imagen 3 de 3
    • Turn the computer right side up with the front facing towards you.
  5. HP Chromebook 14-x010wm Touchpad Replacement: paso 5, imagen 1 de 2 HP Chromebook 14-x010wm Touchpad Replacement: paso 5, imagen 2 de 2
    • Carefully open the computer’s lid as far as it will go until the back edge of the keyboard cover separates from the base.
    • Opening the lid too far may cause damage to some of the internal pieces of the laptop.
  6. HP Chromebook 14-x010wm Touchpad Replacement: paso 6, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 6, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, pry open along the front edge and the sides of the keyboard cover to separate it from the computer’s base.
    • Carefully lift the keyboard cover from the computer’s base.
    • Lifting the keyboard cover too much may damage the internal cables of the laptop.
  7. HP Chromebook 14-x010wm Touchpad Replacement: paso 7, imagen 1 de 2 HP Chromebook 14-x010wm Touchpad Replacement: paso 7, imagen 2 de 2
    • Using a spudger, remove the battery cable by slowly pulling the plastic connector towards you.
  8. HP Chromebook 14-x010wm Touchpad Replacement: paso 8, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 8, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 8, imagen 3 de 3
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the keyboard cable in place.
    • Disconnect the keyboard cable by pulling it from the system board.
  9. HP Chromebook 14-x010wm Touchpad Replacement: paso 9, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 9, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 9, imagen 3 de 3
    • Using a spudger, lift the black plastic flap of the zero insertion force (ZIF) connector that holds the TouchPad cable in place.
    • Disconnect the TouchPad cable by pulling it from the system board.
    • At this point, the keyboard cover should be completely detached from the computer’s base.
  10. HP Chromebook 14-x010wm Touchpad Replacement: paso 10, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 10, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 10, imagen 3 de 3
    • Remove the keyboard cover by sliding it towards you.
    • Turn the keyboard cover upside down.
  11. HP Chromebook 14-x010wm Touchpad Replacement: paso 11, imagen 1 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 11, imagen 2 de 3 HP Chromebook 14-x010wm Touchpad Replacement: paso 11, imagen 3 de 3
    • Using a spudger, lift the black plastic flap to release the TouchPad cable from the connector.
    • Disconnect the TouchPad cable by pulling it away from the connector.
  12. HP Chromebook 14-x010wm Touchpad Replacement: paso 12, imagen 1 de 2 HP Chromebook 14-x010wm Touchpad Replacement: paso 12, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the two 2.4 mm screws that secure the TouchPad to the keyboard cover.
  13. HP Chromebook 14-x010wm Touchpad Replacement: paso 13, imagen 1 de 2 HP Chromebook 14-x010wm Touchpad Replacement: paso 13, imagen 2 de 2
    • Lift the keyboard cover. The TouchPad will be detached.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 15-2, Remmell Spring 2017 Miembro de USF Tampa, Team 15-2, Remmell Spring 2017
USFT-REMMELL-S17S15G2
4 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,983
