Saltar al contenido principal
HP Chromebook 14-q010nr Motherboard Replacement
Qué necesitas
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Motherboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-q010nr Motherboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-q010nr Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: paso 4, imagen 1 de 1
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: paso 5, imagen 1 de 2 HP Chromebook 14-q010nr Motherboard Replacement: paso 5, imagen 2 de 2
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
Conclusión
Julian Knight
Miembro Desde 09/22/22
159 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 156
