Saltar al contenido principal
HP Chromebook 14-q010nr Key Replacement
Qué necesitas
  1. HP Chromebook 14-q010nr Key Replacement, Key: paso 1, imagen 1 de 2 HP Chromebook 14-q010nr Key Replacement, Key: paso 1, imagen 2 de 2
    • Press on a key above the key you want to replace.
    • Place a flat object, like an iFixit opening tool in this case, under the broken key and lift upwards to remove it.
  2. HP Chromebook 14-q010nr Key Replacement: paso 2, imagen 1 de 1
    • Align the square plastic bracket to make sure the keys fits there if the bracket moved.
    • Note for missing keys: if this is missing, purchase a new one and align and insert in missing key area.
  3. HP Chromebook 14-q010nr Key Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-q010nr Key Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-q010nr Key Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Place the new key gently into place. Tweezers can help with the process.
    • Align the new key in the area and press on it to attach it in place.
    • It may not attach until you hear a click or snap noise, so take your time attaching the new key.
    • Do not press too hard on the new key lest you break it.
Conclusión
To reassemble your device, follow these steps in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 125
