Saltar al contenido principal
HP Chromebook 14-ca061dx Motherboard Replacement
Qué necesitas
  1. HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement, Keyboard: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Motherboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Motherboard Replacement: paso 3, imagen 1 de 2 HP Chromebook 14-ca061dx Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Motherboard Replacement: paso 4, imagen 1 de 2 HP Chromebook 14-ca061dx Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Motherboard Replacement: paso 5, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 5, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 5, imagen 3 de 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Motherboard Replacement: paso 6, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 6, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Motherboard Replacement: paso 7, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 7, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 7, imagen 3 de 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
  9. HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: paso 9, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: paso 9, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement, Motherboard: paso 9, imagen 3 de 3
    • Peel back the black electrical tape from the wires connecting the battery to the motherboard using tweezers.
    • Pull the white plastic piece toward you using your finger to disconnect the wires.
    • Make sure to pull the plastic and not the wires, because pulling the wires could cause them to break.
  10. HP Chromebook 14-ca061dx Motherboard Replacement: paso 10, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 10, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 10, imagen 3 de 3
    • Peel back the plastic covering on the wires connecting the speaker to the motherboard.
    • Using your finger, pull the white plastic piece toward you and remove.
    • Make sure to avoid pulling the wires, for it may cause them to break.
  11. HP Chromebook 14-ca061dx Motherboard Replacement: paso 11, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 11, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 11, imagen 3 de 3
    • Pull back the plastic covering of the cables connecting the motherboard to the daughter-board using tweezers.
    • Flip up both of the black plastic pieces using the spudger.
    • Remove both of the blue and white cables by pulling the blue plastic pieces toward you.
    • Disconnect the cables carefully because they are fragile.
  12. HP Chromebook 14-ca061dx Motherboard Replacement: paso 12, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 12, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 12, imagen 3 de 3
    • Peel back the plastic covering of the WiFi card using tweezers.
    • With a JIS J000 head, remove the 2mm screw.
    • Pull the WiFi card toward the left to remove.
  13. HP Chromebook 14-ca061dx Motherboard Replacement: paso 13, imagen 1 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 13, imagen 2 de 3 HP Chromebook 14-ca061dx Motherboard Replacement: paso 13, imagen 3 de 3
    • Peel back the plastic covering on the wires connecting the screen to the motherboard using tweezers.
    • Peel back the black electrical tape using tweezers.
    • Remove the wires by pulling the plastic piece away from you.
    • Make sure to pull the plastic piece and not the wires because the wires are fragile.
  14. HP Chromebook 14-ca061dx Motherboard Replacement: paso 14, imagen 1 de 2 HP Chromebook 14-ca061dx Motherboard Replacement: paso 14, imagen 2 de 2
    • Using a PH0 head, remove the two 4 mm screws from the metal piece.
    • Remove the metal piece using tweezers.
  15. HP Chromebook 14-ca061dx Motherboard Replacement: paso 15, imagen 1 de 2 HP Chromebook 14-ca061dx Motherboard Replacement: paso 15, imagen 2 de 2
    • Remove the four, 4 mm screws from the motherboard using a PH0 head.
    • Remove the motherboard from the Chromebook.
Conclusión
Jean Arevalo
Miembro Desde 10/31/19
778 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Miembro de UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,008
