Saltar al contenido principal
HP Chromebook 14-ak041dx USB Board Replacement
Qué necesitas
  1. HP Chromebook 14-ak041dx USB Board Replacement, Keyboard: paso 1, imagen 1 de 2 HP Chromebook 14-ak041dx USB Board Replacement, Keyboard: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx USB Board Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 2, imagen 3 de 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx USB Board Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 3, imagen 3 de 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx USB Board Replacement, Battery: paso 4, imagen 1 de 2 HP Chromebook 14-ak041dx USB Board Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx USB Board Replacement: paso 5, imagen 1 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 5, imagen 2 de 3 HP Chromebook 14-ak041dx USB Board Replacement: paso 5, imagen 3 de 3
    Comprar
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx USB Board Replacement: paso 6, imagen 1 de 1
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx USB Board Replacement, USB Board: paso 7, imagen 1 de 2 HP Chromebook 14-ak041dx USB Board Replacement, USB Board: paso 7, imagen 2 de 2
    • Remove the two 1.5mm Phillips #000 screws from the USB board.
  8. HP Chromebook 14-ak041dx USB Board Replacement: paso 8, imagen 1 de 2 HP Chromebook 14-ak041dx USB Board Replacement: paso 8, imagen 2 de 2
    • Carefully lift the USB board from the computer.
    • When replacing your new USB board, insert the USB slots through the opening in the metal frame first, and then lay the rest of the USB board down.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 162
