Saltar al contenido principal
HP Chromebook 14-ak013dx Internal Speaker Replacement
Qué necesitas
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: paso 1, imagen 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: paso 1, imagen 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: paso 1, imagen 3 de 3
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: paso 2, imagen 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: paso 2, imagen 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: paso 2, imagen 3 de 3
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: paso 3, imagen 1 de 1
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: paso 4, imagen 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: paso 4, imagen 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: paso 4, imagen 3 de 3
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: paso 5, imagen 1 de 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: paso 5, imagen 2 de 2
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: paso 6, imagen 1 de 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: paso 6, imagen 2 de 2
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
Conclusión
Una persona más ha completado esta guía.
Equipo
dwsad Miembro de dwsad
Community
1 Miembro
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 76
