Introducción
The HP Chromebook 14-ak013dx has a removable battery located beneath the keyboard. This battery is easily removable to allow replacement of the battery after degradation. A new battery can restore the original battery life of the device.
Qué necesitas
Turn the Chromebook upside down, as shown in the first image.
Remove the five rubber feet pieces as shown using a metal spudger.
Begin removal of the back panel by unscrewing all exposed screws using a small Phillips screwdriver.
Use a plastic prying tool to split the back panel from the keyboard.
Move the prying tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
