Saltar al contenido principal
HP Chromebook 14-Q070NR Battery Replacement
Qué necesitas
  1. HP Chromebook 14-Q070NR Battery Replacement, Keyboard: paso 1, imagen 1 de 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Battery Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 2, imagen 3 de 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Battery Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 3, imagen 3 de 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Battery Replacement: paso 4, imagen 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 4, imagen 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: paso 4, imagen 3 de 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Battery Replacement: paso 6, imagen 1 de 2 HP Chromebook 14-Q070NR Battery Replacement: paso 6, imagen 2 de 2
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Battery Replacement: paso 7, imagen 1 de 1
    • Carefully lift the battery and remove it from the device.
Conclusión
Andres Martinez
Miembro Desde 10/02/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S9-G5, Remmell Fall 2017 Miembro de USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 397
