Introducción
This guide requires the removal of 1x5mm screws on the USB/SD card assembly.
Qué necesitas
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Casi Terminas!
Conclusión
