Saltar al contenido principal
HP Chromebook 14-Q010DX Motherboard Replacement
Qué necesitas
  1. HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: paso 1, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: paso 1, imagen 2 de 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Motherboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 2, imagen 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Motherboard Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 3, imagen 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Motherboard Replacement: paso 4, imagen 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Motherboard Replacement: paso 5, imagen 1 de 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: paso 6, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: paso 6, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: paso 6, imagen 3 de 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
  7. HP Chromebook 14-Q010DX Motherboard Replacement: paso 7, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement: paso 7, imagen 2 de 2
    • Gently remove the speakers.
  8. HP Chromebook 14-Q010DX Motherboard Replacement, Battery: paso 8, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Battery: paso 8, imagen 2 de 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
  9. HP Chromebook 14-Q010DX Motherboard Replacement: paso 9, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 9, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
  10. HP Chromebook 14-Q010DX Motherboard Replacement: paso 10, imagen 1 de 1
    • Gently remove battery.
  11. HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: paso 11, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: paso 11, imagen 2 de 2
    • Using a spudger, remove the white and black cables from the card.
  12. HP Chromebook 14-Q010DX Motherboard Replacement: paso 12, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove screw from card.
  13. HP Chromebook 14-Q010DX Motherboard Replacement: paso 13, imagen 1 de 1
    • Gently pull card at a 45° angle to remove it.
  14. HP Chromebook 14-Q010DX Motherboard Replacement, Fan: paso 14, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan: paso 14, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan: paso 14, imagen 3 de 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
  15. HP Chromebook 14-Q010DX Motherboard Replacement: paso 15, imagen 1 de 1
    • Gently remove fan.
  16. HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: paso 16, imagen 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: paso 16, imagen 2 de 2
    • Using your fingers or spudger, pull out the connector.
  17. HP Chromebook 14-Q010DX Motherboard Replacement: paso 17, imagen 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 17, imagen 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: paso 17, imagen 3 de 3
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
  18. HP Chromebook 14-Q010DX Motherboard Replacement: paso 18, imagen 1 de 1
    • Gently remove motherboard.
Conclusión
2 personas más completaron esta guía.
Kevin Piper
Miembro Desde 01/16/15
1,599 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 17-2, Watkins Winter 2015 Miembro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Miembros
8 Guías creadas
4 comentarios
Can someone just explain for what the sensor board is needed?
martindoerflinger - Contestar
Let's the motherboard know when the lid is closed.
Jeff Briedwell -
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
Stefan - Contestar
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
david saldivias - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 4,604
