Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Chromebook 14-Q010DX Fan Replacement
Qué necesitas
  1. HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: paso 1, imagen 1 de 2 HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: paso 1, imagen 2 de 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
  2. HP Chromebook 14-Q010DX Fan Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-Q010DX Fan Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-Q010DX Fan Replacement: paso 2, imagen 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Fan Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-Q010DX Fan Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-Q010DX Fan Replacement: paso 3, imagen 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Fan Replacement: paso 4, imagen 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Fan Replacement: paso 5, imagen 1 de 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: paso 6, imagen 1 de 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: paso 6, imagen 2 de 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: paso 6, imagen 3 de 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
  7. HP Chromebook 14-Q010DX Fan Replacement: paso 7, imagen 1 de 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
Conclusión
5 personas más completaron esta guía.
Kevin Piper
Miembro Desde 01/16/15
1,602 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 17-2, Watkins Winter 2015 Miembro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
Miembros de 4
8 Guías creadas
1Guía Comentario
Add Comment:
Akshit Fnu - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 49
Todo El Tiempo: 4,177
