Introducción
This guide will require removal of 1x3mm screws on the bluetooth and wireless card.
Herramientas
Partes
The yellow circle represents the rubber covering that protects the screw. And the red circle represents the screws.
Flip the laptop such that the base of the laptop should face you. Remove the rubber covering with help of any sharp pointed object and then unscrew the screw.
Using a spudger, remove the white and black cables from the card as indicated by the red circles in the pictures.
Una persona más ha completado esta guía.
