Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Chromebook 14-Q010DX Battery Replacement
Qué necesitas
  1. HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: paso 1, imagen 1 de 2 HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: paso 1, imagen 2 de 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Pregunta a FixBot
  2. HP Chromebook 14-Q010DX Battery Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 2, imagen 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Pregunta a FixBot
  3. HP Chromebook 14-Q010DX Battery Replacement: paso 3, imagen 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 3, imagen 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 3, imagen 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Pregunta a FixBot
  4. HP Chromebook 14-Q010DX Battery Replacement: paso 4, imagen 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Pregunta a FixBot
  5. HP Chromebook 14-Q010DX Battery Replacement: paso 5, imagen 1 de 1
    • Set aside the detached keyboard.
    Pregunta a FixBot
  6. HP Chromebook 14-Q010DX Battery Replacement, Speaker: paso 6, imagen 1 de 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: paso 6, imagen 2 de 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: paso 6, imagen 3 de 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Pregunta a FixBot
  7. HP Chromebook 14-Q010DX Battery Replacement: paso 7, imagen 1 de 2 HP Chromebook 14-Q010DX Battery Replacement: paso 7, imagen 2 de 2
    • Gently remove the speakers.
    Pregunta a FixBot
  8. HP Chromebook 14-Q010DX Battery Replacement, Battery: paso 8, imagen 1 de 2 HP Chromebook 14-Q010DX Battery Replacement, Battery: paso 8, imagen 2 de 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Pregunta a FixBot
  9. HP Chromebook 14-Q010DX Battery Replacement: paso 9, imagen 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 9, imagen 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: paso 9, imagen 3 de 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Pregunta a FixBot
  10. HP Chromebook 14-Q010DX Battery Replacement: paso 10, imagen 1 de 1
    • Gently remove battery.
    Pregunta a FixBot
Conclusión
6 personas más completaron esta guía.
Kevin Piper
Miembro Desde 01/16/15
1,602 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 17-2, Watkins Winter 2015 Miembro de USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
Miembros de 4
8 Guías creadas
3Guía Comentarios
Nice guide, guys!
dergrossmeister50 - Contestar Compartir
Thanks, hope it made life a bit easier for you!
Kevin Piper - Contestar Compartir
Very clear and concise. Nice going! Thank you.
sparkydog1725 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 68
Todo El Tiempo: 14,261
