Saltar al contenido principal
HP Chromebook 11A G8 EE Wi-Fi Card Replacement
Qué necesitas
  1. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: paso 1, imagen 1 de 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Keyboard Assembly: paso 1, imagen 2 de 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 2, imagen 1 de 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 2, imagen 2 de 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 3, imagen 1 de 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Wi-Fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using your tweezers, unplug the battery connector from the motherboard.
  5. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 5, imagen 1 de 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 5, imagen 2 de 3 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Using your tweezers, peel back the clear sheet covering the Wi-Fi card.
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card cover.
    • Using your tweezers, remove the cover.
  6. HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 6, imagen 1 de 2 HP Chromebook 11A G8 EE Wi-Fi Card Replacement: paso 6, imagen 2 de 2
    • Using your tweezers, unsnap the the coaxial antenna cables from the Wi-Fi Card.
    • Slide the Wi-Fi card out.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 919
