Saltar al contenido principal
HP Chromebook 11-v011dx Speaker Replacement
Qué necesitas
  1. HP Chromebook 11-v011dx Speaker  Replacement, Key Board: paso 1, imagen 1 de 3 HP Chromebook 11-v011dx Speaker  Replacement, Key Board: paso 1, imagen 2 de 3 HP Chromebook 11-v011dx Speaker  Replacement, Key Board: paso 1, imagen 3 de 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Speaker  Replacement: paso 2, imagen 1 de 2 HP Chromebook 11-v011dx Speaker  Replacement: paso 2, imagen 2 de 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Speaker  Replacement: paso 3, imagen 1 de 2 HP Chromebook 11-v011dx Speaker  Replacement: paso 3, imagen 2 de 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Speaker  Replacement: paso 4, imagen 1 de 3 HP Chromebook 11-v011dx Speaker  Replacement: paso 4, imagen 2 de 3 HP Chromebook 11-v011dx Speaker  Replacement: paso 4, imagen 3 de 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Speaker  Replacement: paso 5, imagen 1 de 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
  6. HP Chromebook 11-v011dx Speaker  Replacement, Battery: paso 6, imagen 1 de 2 HP Chromebook 11-v011dx Speaker  Replacement, Battery: paso 6, imagen 2 de 2
    • Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
  7. HP Chromebook 11-v011dx Speaker  Replacement: paso 7, imagen 1 de 1
    • Make sure to hold the white tab portion of the plug and not the wire itself. If you unplug it by holding the wires, you may rip out the wires.
    • Slowly unplug the wire that connects the battery to the motherboard with your hands.
  8. HP Chromebook 11-v011dx Speaker  Replacement: paso 8, imagen 1 de 1
    • There is a thick black wire strip that is going across the battery for a different part of the HP ChromeBook 11-v011dx. Be mindful when removing the motherboard so you do not damage this strip.
    • Remove the battery carefully using your hands.
  9. HP Chromebook 11-v011dx Speaker  Replacement, Speaker: paso 9, imagen 1 de 2 HP Chromebook 11-v011dx Speaker  Replacement, Speaker: paso 9, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the one 1.3mm screw that connects the speakers and the motherboard together.
  10. HP Chromebook 11-v011dx Speaker  Replacement: paso 10, imagen 1 de 1
    • Make sure to hold the white part of the plug and not the wire. If unplugged by holding the wires, it can rip out wires.
    • Slowly and cautiously unplug the wire that connects the speakers to the motherboard with your hands.
  11. HP Chromebook 11-v011dx Speaker  Replacement: paso 11, imagen 1 de 2 HP Chromebook 11-v011dx Speaker  Replacement: paso 11, imagen 2 de 2
    • Be careful with the wire between both end of the speakers. It's between metal parts and can get caught.
    • Slowly remove both ends of the speakers with your hands.
Conclusión
Kyle DeMello
Miembro Desde 10/20/17
542 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 122
