Saltar al contenido principal
HP Chromebook 11-v002dx Screen Replacement
Qué necesitas
  1. HP Chromebook 11-v002dx Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Insert your spudger between the plastic covering and the back of the case.
  2. HP Chromebook 11-v002dx Screen Replacement: paso 2, imagen 1 de 1
    • With the help of your spudger completely remove the plastic cover from the rest of the case.
  3. HP Chromebook 11-v002dx Screen Replacement: paso 3, imagen 1 de 1
    • Your screen will look like this.
  4. HP Chromebook 11-v002dx Screen Replacement: paso 4, imagen 1 de 2 HP Chromebook 11-v002dx Screen Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 Screwdriver, remove the four 2.5mm screws holding the screen in place.
  5. HP Chromebook 11-v002dx Screen Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the tape covering the wiring and detach the ribbon cable that secures the screen to the motherboard.
    • Use tweezers if you can't reach it with your fingers.
  6. HP Chromebook 11-v002dx Screen Replacement: paso 6, imagen 1 de 2 HP Chromebook 11-v002dx Screen Replacement: paso 6, imagen 2 de 2
    • Remove the display and the case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 142
