Saltar al contenido principal
HP Chromebook 11-v002dx Keyboard Replacement
Qué necesitas
  1. HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Keyboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 11-v002dx Keyboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 11-v002dx Keyboard Replacement: paso 2, imagen 3 de 3
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Keyboard Replacement: paso 3, imagen 1 de 2 HP Chromebook 11-v002dx Keyboard Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Keyboard Replacement: paso 4, imagen 1 de 2 HP Chromebook 11-v002dx Keyboard Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
Conclusión
Una persona más ha completado esta guía.
Heather Cooper
Miembro Desde 04/18/17
185 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S14-G1, Banghart Spring 2017 Miembro de Cal Poly, Team S14-G1, Banghart Spring 2017
CPSU-BANGHART-S17S14G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 677
