Saltar al contenido principal
HP Chromebook 11-2210nr LCD Screen Replacement
Qué necesitas
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: paso 3, imagen 1 de 2 HP Chromebook 11-2210nr LCD Screen Replacement: paso 3, imagen 2 de 2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: paso 4, imagen 1 de 2 HP Chromebook 11-2210nr LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: paso 5, imagen 1 de 1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: paso 6, imagen 1 de 2 HP Chromebook 11-2210nr LCD Screen Replacement: paso 6, imagen 2 de 2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: paso 7, imagen 1 de 2 HP Chromebook 11-2210nr LCD Screen Replacement: paso 7, imagen 2 de 2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 331
