Saltar al contenido principal
HP Chromebook 11-2210nr Keyboard Replacement
Qué necesitas
  1. HP Chromebook 11-2210nr Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 HP Chromebook 11-2210nr Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Keyboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 2, imagen 3 de 3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr Keyboard Replacement: paso 3, imagen 1 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 3, imagen 2 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 3, imagen 3 de 3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr Keyboard Replacement: paso 4, imagen 1 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 4, imagen 2 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 4, imagen 3 de 3
    • Carefully lift off the keyboard and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two chips.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Keyboard Replacement: paso 5, imagen 1 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 5, imagen 2 de 3 HP Chromebook 11-2210nr Keyboard Replacement: paso 5, imagen 3 de 3
    • Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is recommended to use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
Conclusión
Bridget Rosales
Miembro Desde 10/02/18
121 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 212
