Introducción
This guide will show you the correct way to remove the battery according to an HP Chromebook 11-2210nr in the need to replace a faulty or damaged battery. Once the battery is removed, access to speakers is more accessible.
Qué necesitas
Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
Casi Terminas!
Conclusión
