Saltar al contenido principal
HP Chromebook 11-2210nr Battery Replacement
Qué necesitas
  1. HP Chromebook 11-2210nr Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Chromebook 11-2210nr Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Battery Replacement: paso 2, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 2, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 2, imagen 3 de 3
    • Use a metal spudger to remove the two bottom rubber pads located closer to the hinge of the laptop.
    • Remove the two additional 6 mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The other two bottom rubber pads do not have screws beneath them.
  3. HP Chromebook 11-2210nr Battery Replacement: paso 3, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 3, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 3, imagen 3 de 3
    • Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
    • Be careful when using the metal spudger as it could cause damage to the internals of the device. Don't push the spudger too deeply into the seam.
  4. HP Chromebook 11-2210nr Battery Replacement: paso 4, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 4, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 4, imagen 3 de 3
    • Carefully lift the keyboard up and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two locks.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Battery Replacement: paso 5, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 5, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 5, imagen 3 de 3
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is important to use the nylon spudger for this step to avoid any metal on metal circuit damage.
    • This step completely disconnects the keyboard to allow safe removal.
  6. HP Chromebook 11-2210nr Battery Replacement: paso 6, imagen 1 de 2 HP Chromebook 11-2210nr Battery Replacement: paso 6, imagen 2 de 2
    • Remove the six 4 mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Battery Replacement: paso 7, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 7, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 7, imagen 3 de 3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Battery Replacement: paso 8, imagen 1 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 8, imagen 2 de 3 HP Chromebook 11-2210nr Battery Replacement: paso 8, imagen 3 de 3
    • Carefully lift the battery and remove it from the laptop.
    • The battery may have an adhesive sticker attached to the bottom, if so apply more force when lifting up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 344
