Saltar al contenido principal
HP Chromebook 11 G8 EE Bezel Replacement
Qué necesitas
  1. HP Chromebook 11 G8 EE Bezel Replacement, Keyboard & Touchpad Assembly: paso 1, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Bezel Replacement: paso 2, imagen 1 de 2 HP Chromebook 11 G8 EE Bezel Replacement: paso 2, imagen 2 de 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Bezel Replacement: paso 3, imagen 1 de 3 HP Chromebook 11 G8 EE Bezel Replacement: paso 3, imagen 2 de 3 HP Chromebook 11 G8 EE Bezel Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Bezel Replacement, Bezel: paso 4, imagen 1 de 2 HP Chromebook 11 G8 EE Bezel Replacement, Bezel: paso 4, imagen 2 de 2
    • Using your hands, pry off the hinge cover by lifting it.
  5. HP Chromebook 11 G8 EE Bezel Replacement: paso 5, imagen 1 de 3 HP Chromebook 11 G8 EE Bezel Replacement: paso 5, imagen 2 de 3 HP Chromebook 11 G8 EE Bezel Replacement: paso 5, imagen 3 de 3
    • Using the opening tool, pry the bezel away from the top case.
    • It requires a bit of force; you aren't going to break it!
  6. HP Chromebook 11 G8 EE Bezel Replacement: paso 6, imagen 1 de 1
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
  7. HP Chromebook 11 G8 EE Bezel Replacement: paso 7, imagen 1 de 1
    • Completely remove the bezel.
Conclusión
Una persona más ha completado esta guía.
Isabella Brown
Miembro Desde 10/25/22
312 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 291
