Introducción
This is a replacement guide for the HP Chromebook 11 G5 screen. The main purpose of the steps below is to show you how to replace the screen. The screen is the most important output device of the Chromebook and is required to display information visually. Symptoms of a defective screen include an unresponsive, black screen after the device has been powered on and streaking lines or distorted images being displayed. If these steps are followed carefully and correctly the screen should be easily replaced. Be sure to power off your device before beginning the replacement process.
Qué necesitas
Open the lid as far as possible.
Slide your spudger into the bezel of the laptop until it appears on the other side.
Make your way around the bezel with the spudger while gently prying up the bezel to snap it out of place.
2 personas más completaron esta guía.
