Saltar al contenido principal
HP Chromebook 11 G5 Motherboard Replacement
Qué necesitas
  1. HP Chromebook 11 G5 Motherboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Motherboard Replacement: paso 4, imagen 1 de 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Motherboard Replacement: paso 5, imagen 1 de 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Motherboard Replacement: paso 6, imagen 1 de 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Motherboard Replacement: paso 8, imagen 1 de 1
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Remove the 4mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  10. HP Chromebook 11 G5 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the two wires from the top of the Wi-Fi card by gently pushing them away from the sockets they are connected to using the pointed end of a spudger.
    • The Wi-Fi card can now be removed from the base of the device by hand.
  11. HP Chromebook 11 G5 Motherboard Replacement: paso 11, imagen 1 de 1
    • Release the ribbon cable connecting the motherboard to the Hall effect sensor by lifting the plastic connector lid using the pointed end of a spudger.
    • You can now remove the ribbon cable from the motherboard by gently pulling it with your hand.
    • Handle ribbon cables carefully as they are fragile and easily torn.
  12. HP Chromebook 11 G5 Motherboard Replacement: paso 12, imagen 1 de 2 HP Chromebook 11 G5 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the battery connector by pushing both ends away from the motherboard one at a time using the pointed end of a spudger.
  13. HP Chromebook 11 G5 Motherboard Replacement: paso 13, imagen 1 de 1
    • Disconnect the right-side speaker by pushing both ends of the connector away from the motherboard one at a time using the pointed end of a spudger.
    • This may require force.
  14. HP Chromebook 11 G5 Motherboard Replacement: paso 14, imagen 1 de 2 HP Chromebook 11 G5 Motherboard Replacement: paso 14, imagen 2 de 2
    • Peel the tape over the display cable before lifting the plastic connector lid holding it in place by using the pointed end of a spudger.
    • Remove the cable by gently pulling it with your hand.
  15. HP Chromebook 11 G5 Motherboard Replacement: paso 15, imagen 1 de 2 HP Chromebook 11 G5 Motherboard Replacement: paso 15, imagen 2 de 2
    • Peel the tape over the camera connector before lifting the plastic connector lid holding it in place by using the pointed end of a spudger.
  16. HP Chromebook 11 G5 Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the charging port connector by pulling both ends away from the motherboard using your fingers.
    • This can be done by using the pointed end of a spudger if you are not comfortable using your fingers.
  17. HP Chromebook 11 G5 Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove the five 4mm screws from the motherboard using a Phillips #00 screwdriver.
    • The screw beside the battery is black, while the rest are silver.
  18. HP Chromebook 11 G5 Motherboard Replacement: paso 18, imagen 1 de 1
    • Gently remove the motherboard by hand from the base of the device.
Conclusión
2 personas más completaron esta guía.
Jaspal Kang
Miembro Desde 01/14/20
277 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 39
Todo El Tiempo: 1,317
