Saltar al contenido principal
HP Chromebook 11 G5 DC Charging Port Replacement
Qué necesitas
  1. HP Chromebook 11 G5 DC Charging Port Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 DC Charging Port Replacement: paso 2, imagen 1 de 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 DC Charging Port Replacement: paso 3, imagen 1 de 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 DC Charging Port Replacement: paso 4, imagen 1 de 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 DC Charging Port Replacement: paso 5, imagen 1 de 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 DC Charging Port Replacement: paso 6, imagen 1 de 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 DC Charging Port Replacement: paso 7, imagen 1 de 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 DC Charging Port Replacement: paso 8, imagen 1 de 1
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 DC Charging Port Replacement, DC Charging Port: paso 9, imagen 1 de 1
    • Disconnect the charging port cable from the motherboard using your finger or a spudger and gently pull it off.
  10. HP Chromebook 11 G5 DC Charging Port Replacement: paso 10, imagen 1 de 1
    • Remove the two screws from the hinge of the device using a Phillips #00 screwdriver.
    • Carefully lift the hinge up.
  11. HP Chromebook 11 G5 DC Charging Port Replacement: paso 11, imagen 1 de 1
    • Carefully lift the charging port cable with the hinge up to remove the DC charging port.
  12. HP Chromebook 11 G5 DC Charging Port Replacement: paso 12, imagen 1 de 1
    • Carefully remove the DC charging port from the base using a spudger.
Conclusión
2 personas más completaron esta guía.
Salma Zitoun
Miembro Desde 01/14/20
367 Reputación
2 Guías creadas
Equipo
2 comentarios
I thought it was going to be a little bit more difficult than it was . I got it done in about 15-20 minutes. Thanks to this.
Maryann Charles - Contestar
Do you guys sell these replacement DC Ports or know where to find them? (I work for a school, but the students keep breaking things! I need, like, 25 of these… yep, it’s that bad. Even found a literal nest of cockroaches inside one of them. I still have the picture/video of it for the morbidly curious lol.)
Aaron Yamauchi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,232
