Saltar al contenido principal
HP Chromebook 11 G4 SD Card Reader Replacement
Qué necesitas
  1. HP Chromebook 11 G4 SD Card Reader Replacement, Keyboard: paso 1, imagen 1 de 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 SD Card Reader Replacement: paso 2, imagen 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: paso 2, imagen 2 de 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 SD Card Reader Replacement: paso 3, imagen 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: paso 3, imagen 2 de 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 SD Card Reader Replacement: paso 4, imagen 1 de 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 SD Card Reader Replacement: paso 5, imagen 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: paso 5, imagen 2 de 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 SD Card Reader Replacement: paso 6, imagen 1 de 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 SD Card Reader Replacement: paso 7, imagen 1 de 3 HP Chromebook 11 G4 SD Card Reader Replacement: paso 7, imagen 2 de 3 HP Chromebook 11 G4 SD Card Reader Replacement: paso 7, imagen 3 de 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 SD Card Reader Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: paso 9, imagen 1 de 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: paso 9, imagen 2 de 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: paso 9, imagen 3 de 3
    • Flip up the flap on the ZIP connector with your finger.
    • Gently pull out the ribbon cable.
  10. HP Chromebook 11 G4 SD Card Reader Replacement: paso 10, imagen 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: paso 10, imagen 2 de 2
    • Remove the two 4 mm Phillips #1 screws.
  11. HP Chromebook 11 G4 SD Card Reader Replacement: paso 11, imagen 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: paso 11, imagen 2 de 2
    • Lift the ribbon cable back and out of the way.
    • Pull out the SD card reader.
Conclusión
2 personas más completaron esta guía.
Jair Herrera
Miembro Desde 04/26/17
694 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S16-G5, Banghart Winter 2018 Miembro de Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,089
