Saltar al contenido principal
HP Chromebook 11 G3 Display Assembly Replacement
Qué necesitas
  1. HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: paso 1, imagen 1 de 2 HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: paso 1, imagen 2 de 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Display Assembly Replacement: paso 2, imagen 1 de 2 HP Chromebook 11 G3 Display Assembly Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Display Assembly Replacement: paso 4, imagen 1 de 3 HP Chromebook 11 G3 Display Assembly Replacement: paso 4, imagen 2 de 3 HP Chromebook 11 G3 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Display Assembly Replacement: paso 5, imagen 1 de 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Display Assembly Replacement, Display Assembly: paso 6, imagen 1 de 1
    • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
  7. HP Chromebook 11 G3 Display Assembly Replacement: paso 7, imagen 1 de 2 HP Chromebook 11 G3 Display Assembly Replacement: paso 7, imagen 2 de 2
    • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  8. HP Chromebook 11 G3 Display Assembly Replacement: paso 8, imagen 1 de 1
    • Free the wire from the casing.
  9. HP Chromebook 11 G3 Display Assembly Replacement: paso 9, imagen 1 de 1
    • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
    • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
  10. HP Chromebook 11 G3 Display Assembly Replacement: paso 10, imagen 1 de 1
    • Rotate the lid to a 90-degree angle with the table.
    • Shimmy the lid out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Rahul Goyal
Miembro Desde 04/26/17
1,369 Reputación
10 Guías creadas
Equipo
Cal Poly, Team S23-G3, Livingston Spring 2017 Miembro de Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 21
Todo El Tiempo: 1,581
