Saltar al contenido principal
HP Chromebook 14-x013dx Motherboard Replacement
Qué necesitas
  1. HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: paso 1, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement, Keyboard, Touchpad: paso 1, imagen 2 de 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook  14-x013dx Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook  14-x013dx Motherboard Replacement: paso 3, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement: paso 3, imagen 2 de 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook  14-x013dx Motherboard Replacement: paso 4, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement: paso 4, imagen 2 de 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook  14-x013dx Motherboard Replacement: paso 5, imagen 1 de 3 HP Chromebook  14-x013dx Motherboard Replacement: paso 5, imagen 2 de 3 HP Chromebook  14-x013dx Motherboard Replacement: paso 5, imagen 3 de 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook  14-x013dx Motherboard Replacement, Battery: paso 6, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook  14-x013dx Motherboard Replacement: paso 7, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook  14-x013dx Motherboard Replacement: paso 8, imagen 1 de 2 HP Chromebook  14-x013dx Motherboard Replacement: paso 8, imagen 2 de 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook  14-x013dx Motherboard Replacement: paso 9, imagen 1 de 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: paso 10, imagen 1 de 3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: paso 10, imagen 2 de 3 HP Chromebook  14-x013dx Motherboard Replacement, Motherboard: paso 10, imagen 3 de 3
    • Carefully remove the 4 connections.
  11. HP Chromebook  14-x013dx Motherboard Replacement: paso 11, imagen 1 de 3 HP Chromebook  14-x013dx Motherboard Replacement: paso 11, imagen 2 de 3 HP Chromebook  14-x013dx Motherboard Replacement: paso 11, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the seven 2mm screws holding the motherboard in place.
    • Gently lift the motherboard out of the laptop case.
Conclusión
Una persona más ha completado esta guía.
Eile Woeltje
Miembro Desde 11/06/19
304 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G3, Stella Fall 2019 Miembro de IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 550
