Saltar al contenido principal
HP Beats Special Edition 15-p390nr WiFi Card Replacement
Qué necesitas
  1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: paso 1, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: paso 1, imagen 2 de 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 2, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 2, imagen 2 de 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 3, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 3, imagen 2 de 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 4, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 4, imagen 2 de 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 5, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 5, imagen 2 de 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 6, imagen 1 de 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 6, imagen 2 de 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, WiFi Card: paso 7, imagen 1 de 1
    • Once the keyboard panel is removed you will need to locate the WiFi card
  8. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 8, imagen 1 de 1
    • Remove two screws using the Phillips #0 screwdriver.
  9. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 9, imagen 1 de 1
    • Remove wire connected to the back of the card by pulling it straight up.
  10. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: paso 10, imagen 1 de 1
    • Pull card away from you to remove it from the motherboard.
    • Refrain from wiggling or moving the card around, while connected to the motherboard, to prevent damage to connector pins.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 1,117
