Saltar al contenido principal
HP Beats Special Edition 15-p390nr Keyboard Replacement
Qué necesitas
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 2, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 2, imagen 2 de 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 3, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 3, imagen 2 de 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 4, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 4, imagen 2 de 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 5, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 6, imagen 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: paso 6, imagen 2 de 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
Conclusión
4 personas más completaron esta guía.
Un comentario
Can you add if we can take trackpad off the keyboard
Paul Schupbach - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 2,786
