Saltar al contenido principal
HP 8 1401 Rear-Facing Camera Replacement
Qué necesitas
  1. HP 8 1401 Rear-Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Rear-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Rear-Facing Camera Replacement: paso 3, imagen 1 de 2 HP 8 1401 Rear-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 4, imagen 1 de 2 HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
    • Lift the rear-facing camera out of its compartment using the tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 130
