Introducción
This guide will help you if your rear-facing camera is cracked or damaged. You may need to pull a little bit to remove the camera, it is well secured in the tablet.
Qué necesitas
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Casi Terminas!
Conclusión
