Introducción
This guide should be used if the front-facing camera is malfunctioning, cracked, or has other damage.
Qué necesitas
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
Casi Terminas!
Conclusión
